MH20
Joe
02-24-2002 07:07:12
How can I tell exact model when the I.D. plate is gone? And what about the value including corn cultivating units. Is a gear cam operating lift unit under the seat a standard option?
Alberta Mike
02-24-2002 16:45:38
 Re: MH20 in reply to Joe, 02-24-2002 07:07:12
Yes, as mentioned the ID # is hand-stamped into the top of the tranny between the cast iron shifting platform and the metal plate that bolts over the differential. It's on the clutch side so be prepared to do a bit of scraping and wire-brushing to find it ... it's probably filled with paint and crud. If you post the number here, somebody will tell you the year.
cd
02-24-2002 13:28:40
there is a serial # on top of the transmission case.
