98 Massey
Gerald Mann
03-12-1998 18:45:29
I have a 98 Massey can't find anything on it. Know was made by oliver but like to know how many was made, or sold been told from 225 to 22,000 don't know Serial is 88 103-943 specification no. 39-4211 thanks
tractor is in super condit
ion
andy
03-21-1998 14:29:02
 Re: 98 Massey in reply to Gerald Mann, 03-12-1998 18:45:29
Do you want to sell youp tractor? If so I am interested in it. email me at [email protected]
Scott F
03-18-1998 07:09:55
: I have a 98 Massey can't find anything on it. Know was made by oliver but like to know how many was made, or sold been told from 225 to 22,000 don't know Serial is 88 103-943 specification no. 39-4211 thanks
: tractor is in super condit
The MF-98 was made by Oliver and is really an Oliver 990 with Massey sheet metal. When you look for parts ask for Oliver parts and you might find what you need. The MF-98 was only sold from in 59 and 60. There was less than 400 of them. Nobody knows for sure since Oliver did not seperate out there serial numbers from the 990, 995 or 950. You have a rare tractor. Where are you located and how did you come by it? What did it farm?
Gerald Mann
03-18-1998 19:58:19
 Re: Re: 98 Massey in reply to Scott F, 03-18-1998 07:09:55
: : I have a 98 Massey can't find anything on it. Know was made by oliver but like to know how many was made, or sold been told from 225 to 22,000 don't know Serial is 88 103-943 specification no. 39-4211 thanks
: : tractor is in super condit
: : The MF-98 was made by Oliver and is really an Oliver 990 with Massey sheet metal. When you look for parts ask for Oliver parts and you might find what you need. The MF-98 was only sold from in 59 and 60. There was less than 400 of them. Nobody knows for sure since Oliver did not seperate out there serial numbers from the 990, 995 or 950. You have a rare tractor. Where are you located and how did you come by it? What did it farm?
Thanks for the info. it pretty well matches what was told when I brought this tractor was told 400 made for sellbut only 220 wer put out as fer.pulled off because perkins told them to quit adv.2 stroke diesel or they would pull out This tractor came from Iowa from Greg Sutton and had a cab on it but he had taken it off it is in good shape needs paint, and slobers a lot especially in cool weather butif it didn"t it would not be the old detroit right? am not sure where it really came from north and west I would think, and I lve in ky. central Springfield 40069. Thanks again and if I can help you in any way give me a shout Thanks again Gerald
Scott F
03-20-1998 07:11:08
 Re: Re: Re: 98 Massey in reply to Gerald Mann, 03-18-1998 19:58:19
I looked at one that Greg Sutton had for sell last April of 97. I gets a lot of them some how. I ended paying a little more and for a Oliver Super 99. Did you go to Greg Suttons place? Since then I found a MF-98 on my own and bought it from the farmers son for almost nothing. It is in better shape then the one Greg Sutton had. I need two of the oil bath air filters so if in your search for parts you come across two of them please let me know. Tell me what parts you are looking for and I will see if I can assist you.
As far as the slobbering goes all you have to do is put it under a load for a little while and that sould clear up. Pull something or if you have a PTO put it on a Dyno. The best thing you can do is enter it in a pulling contest. That seats them and it will get a lot more power. What you do not want to do is start it and idle it. Keep the RPMs up. Good luck! Scott
Gerald Mann
03-21-1998 16:38:33
 Re: Re: Re: Re: 98 Massey in reply to Scott F, 03-20-1998 07:11:08
: I looked at one that Greg Sutton had for sell last April of 97. I gets a lot of them some how. I ended paying a little more and for a Oliver Super 99. Did you go to Greg Suttons place? Since then I found a MF-98 on my own and bought it from the farmers son for almost nothing. It is in better shape then the one Greg Sutton had. I need two of the oil bath air filters so if in your search for parts you come across two of them please let me know. Tell me what parts you are looking for and I will see if I can assist you.
: As far as the slobbering goes all you have to do is put it under a load for a little while and that sould clear up. Pull something or if you have a PTO put it on a Dyno. The best thing you can do is enter it in a pulling contest. That seats them and it will get a lot more power. What you do not want to do is start it and idle it. Keep the RPMs up. Good luck!
: Scott
Thanks Scott, just came across yo message will answer we may have looked at the same tractor yes we did go to greg place been there 2 or 3 times he has a couple of detroits around doesn"t he? My tractor seems to be in good shape, has small noise in 4th gear but not bad needs brakes and seals on brake hub thats about it. Last year we did pull it in contest had to pull for fun to heavy got heavy hubs on it weighs 12700 but took sled all the way twice after 10500 boys got done, greghas set of light hubs just can"t find time to go ge them, if I can help you let me know will ask son about breathers he is in to that a lot he has a 990 down putting in transmision good talking with you thanks Gerald
Gerald Mann
03-21-1998 16:36:49
: Scott
Scott F
03-23-1998 07:32:35
 Re: Re: Re: Re: Re: 98 Massey in reply to Gerald Mann , 03-21-1998 16:36:49
That would be great if you could look into those air filters for me. If you find them e-mail directly. That is about the only thing I need to put this thing back to all original condition. I also have the heavy hubs. My MF-98 has 28.1x23 rear tires and one is fill with liquid and the other is filled with powder. I've been told the powder is crushed rock. Any way it wieghs 17,000 pounds the way it sits. I have to get the wieght down to move it with my truck. I got it runing this weekend for the first time in 10 years. Very exciting. The rack was stuck open so it ran away at first. Had to fix that now it runs perfectly. Do you have any information besides what is available in the published books. Greg can tell all about them but I can find the source for is info.
T'NT
03-12-1998 21:26:06
MF 98: Made 1958-1962
Engine: GM 3-71, 3-cylinder, 2-stroke turbo diesel 159 cu. in., 81 hp.
starting with year 53001 1958 71245 1959 84487 1960
110064 1961
118356 1962
MF also sold two tractors made by Minneapolis Moline. Models MF 95 and MF 97. These three were sold to provide their customers with larger tractors until the 1000 series came out.
I do not know how many were made, but if these serial numbers are right it looks like quite a few. I would also like to hear from someone with more info on this interesting tractor.
