Z134 engine took apart years ago, gasket seal questions
greg m
02-19-2002 19:46:29
Ok took this motor apart two years ago, well I am trying to remember how things go back.
One question, the main bearing cap, flywheel side which is big and square and fits into the block tight. It looks like there was a gasket there on either side. I have the gasket kit, the only thing that looks like it would work are cork strips. but the fit is so tight theres no way i could get them in. Is there a gasket there and how would you install it??? If my description needs a picture let me know.
question 2. In the gasket kit there is a pack of string, i assume packing, where is that used?
any other helpful comments.
greg
Bob in CA
02-20-2002 10:36:37
 Re: z134 engine took apart years ago, gasket seal questions in reply to greg m, 02-19-2002 19:46:29
You answered your own question really. The string gets packed into the groove on both sides of the rear main bearing cap. I coated my string with some gasket sealant as I packed it into the hole. It then compressed very tightly in the groove and have had no leaks. There is about four times the string that is necessary to fill the hole so don't worry about that. If I remember right the cork gets used on both front and rear bearing caps to seal the oil pan. Someone else may have other techniques that I would love to hear.
Bob in CA
02-20-2002 10:36:12
