MH444 No Spark
Dennis
02-18-2002 16:24:35
Hi All,
My 56' massey harris 444 LP model 4cyl will not start. .
I Replaced points, rotor, condenser, dist cap, wires and the tractor ran good.
Now it doesn't seem to have any spark at the
points. Today I replaced the coil and it still won't start. HELP PLEASE>
Thank you in advance.
Dennis
Alberta Mike
02-18-2002 19:53:06
 Re: MH444 No Spark in reply to Dennis , 02-18-2002 16:24:35
Assuming that you wired everything back up correctly, then Brad's suggestion is a good one. Meanwhile, recheck your point setting in the distributor and make sure your gap is correct and that the points are closing fully when they should.
Brad Gyde
02-18-2002 19:32:23
Are you getting power to the coil or distributor? That is the only thing I could think (had a similar problem on my 33, bad ignition switch (after new points, condensor, plugs, and coil.... )
Hope this can help,
Brad
Dennis
02-20-2002 16:08:35
 Re: Re: MH444 No Spark in reply to Brad Gyde, 02-18-2002 19:32:23
Hello All,
I replaced the off/on switch and fixed a hot wire that was grounding to the housing and the tractor started right up as usual.
Thank you all for your help.
Dennis
