Massy 165 PTO
Jhon
02-15-2002 09:34:31
Hey I have a MF165 and the rpm pto won't engage when there is anything on the 3 point and hooked to the pto
It works fine when nothing is hooked up
Lee
02-15-2002 15:47:17
 Re: Massy 165 PTO in reply to Jhon, 02-15-2002 09:34:31
Sounds like you have the engine PTO that's not working. Which means that the PTO clutch isn't strong enough to turn the shaft when under load. If you have Multi-power you will lose the high range also, as that is run off the same shaft.
Good luck. Lee
