Massey 240
joel
02-12-2002 09:38:03
Just bought a used massey 240 and I am far from an expert on tractors so I need some information that is probably very basic. A small amount of an oily substance drips from underneath the tractor when I park it. Underneath the tractor, about 1/2 way between the front of the tractor and the front of the seat, there is a small metal loop that looks like the loop end of a cotter pin stuck into a hole. It fits loosely into the hole and this is where the drip comes from. What is it? Is it unusual?
Also, what is the proper way to use the square knob on the draft control.
Any help or comments will be appreciated.
goober
02-12-2002 23:24:30
 Re: massey 240 in reply to joel, 02-12-2002 09:38:03
From Big Dean's Website::
Link
Things to check when buying a MF tractor
On the bell housing there is a weep hole on the bottom it should have a cotter pin head sticking down twist it around Check there for leaks. It Is all right if it is a little damp around it but should not have a steady drip of oil. If the pin head is not there stick something up in the hole and move it around to make sure it is not plug people will plug that hole to hide transmission leaks. It can get very expensive to repair those leaks.
