MF 175 pto clutch
John
02-07-2002 22:51:31
I'm considering buying a MF 175 with 9500 hours on it but in pretty good shape, but the owner said the live pto would slip "a little" when under a heavy load--like powering a large tiller. Any idea what the problem might be and what I'd be facing to fix it?
henning thomssen
02-10-2002 10:57:45
 Re: MF 175 pto clutch in reply to John, 02-07-2002 22:51:31
well,sounds like the clutch is slipping,you'll likely have to split the tractor and replace it.probably should do both the pto and the gearshiftclutches when you're in there.at 9500hrs one would expect a little wear,i figure 800to1000 bucks,to have a mechanic do the job for you.at least here in canada.
