Massy harris 44
Rich Navis
01-01-2000 15:57:55
What is the difference between a massy harris 44 and a massy harris 44 special?
don
01-02-2000 06:28:58
 Re: massy harris 44 in reply to Rich Navis, 01-01-2000 15:57:55
the 44 Special had the factory overbore kit to go from 260 cid. to 277 cid. (4' bore vs. 3 7/8'bore)
I believe the head was ported differently for better cooling.
also, the 44 Special had cast iron rims instead of the stamped steel. Frt. and rear where cast.
the 44 was built from 1946 to 1955.
the special ran from 1953 to 1955.
when the Special first came out, only the gasoline version had the 277 engine, the LP, Diesel and the kerosene models still used the 260 cid. engine
Elmer
01-01-2000 18:53:36
The special was a heavier tractor too. A little longer as well
Tom from Ontario
01-01-2000 17:57:33
Rich: Special was built after the 44. Had the 277 engine instead of the 260.
