MF 40 Industrial brake adj.
Tim
02-04-2002 22:05:35
I cant seem to get a service manual for this unit and I need to adjust the brakes, can someone please tell me how. Thanks Tim
Big Dean
02-05-2002 10:24:50
 Re: MF 40 Industrial brake adj. in reply to Tim, 02-04-2002 22:05:35
Tim the bolt that stick out of the trumpet housing through the brake applying arm will either have a self-locking nut or 2 half nuts when you tight those nuts it increases the brake pedal height. If there are no threads left on the bolt for tightening the brakes are worn out. If you tighten them to tight the brakes will get hot an expand enough to cause them to lock up.
