Hydrolics proublem
Mr.D.
01-01-2000 13:38:51
this is a basic hydrolic proublem. when i try to rasise my hydroilic up there is a "dead spot" and my draw bar drops untill i push it up fother then it catches and raises up. i have replaced the ram, the lines, all the gasgets on the ram, and checked all the gaskets on the pump. i think i covered pretty much every thing and im running out of money for this. im not sure that the handle is the factory one.any help? thanks!
Roland Felton
03-26-2000 05:21:48
 Re: hydrolics proublem in reply to Mr.D., 01-01-2000 13:38:51
Dear Who ever
I have a hydrolic cylinder on a tree planter and when i go to use it. ( there was water in the fluid tank) water flows out of the hydrolic cylinder on the side of the housing, There is a hole there. Is this there for a reason?. I am wondering if this hole is there to led water out if it gets in the tank of fluid. The ram does not hold up it slow falls down and fluid comes our this hole in the side of the cylinder.
P.S. This a one way cylinder Roland
Level
01-01-2000 23:57:16
Have you checked you hydraulic fluid level? Sounds like there is air in your system. The air needs to be purged out of the system by cycling the cylinder up and down the total travel. The system should be main a full level through this process.
