Looking at a MF35
scott potter
02-01-2002 06:55:16
hi folks, I found a clean, working '63 MF35 with a shredder. what should I look out for prior to purchase and can a small front loader be fitted to this machine? thanks, Scott
Frank
02-07-2002 16:05:03
 Re: looking at a MF35 in reply to scott potter, 02-01-2002 06:55:16
I agree if you're opearting in cold weather the gas is a good idea. Look under the tractor on the bottom of the beel housing for any laeks there is a small vent hole which shoiuld have cotter key in it. leaks could mean a bad rear seal especially if the tractor has been sitting, you would have to braek it in two to fix this but it isn't a huge deal. yes you can pu on a number of pipe loadrs meant for the 35's mine has a New Idea "Horn" loader. the hydraulics on the 35 isn't that afst for a loader though.
Orlando
02-02-2002 19:33:05
scott: Big Dean is the guy to ask regarding MF tractors. I just got an MF 35 3 cyl diesel last month and it is one sweet tractor, you will love it. Big deans site is:
Link
Just copy that into your browsers address line and hit the enter button. He is a wealth of information. Good luck! Orlando (Volant, PA)
scott potter
02-04-2002 07:19:56
 Re: Re: looking at a MF35 in reply to Orlando, 02-02-2002 19:33:05
thanks for the comments will go have another look today. It has been shedded or covered most of its life and it has a 3 cylinder....orlando, the link for Big Dean isn't active. but I'll keep checking. cheers, scott
smokey
02-01-2002 19:16:46
Depends which motor is fitted. The 3 cyl 3.152 is best. Has the unit been shedded as water gets into places it should like gear boxes otherwise.
scott potter
02-04-2002 16:05:47
 Re: Re: looking at a MF35 in reply to smokey, 02-01-2002 19:16:46
went and looked at it again today. it is a 4 cyl gas engine.
gary f
02-06-2002 16:45:31
 Re: Re: Re: looking at a MF35 in reply to scott potter, 02-04-2002 16:05:47
I would not shy away from a gas tractor unless it has excessive hours on it. Even then if the price was right you could factor in the cost of a rebuild. Do you know which gas engine it has? Perkins Continental or Standard. The good thing about a gas engine is that they start easily in cold weather and an older diesel could be VERY costly to repair especially if you get into injection pump and injectors\nozzles. A new carb for a gas engine might run $250 US.
Just my 2 cents
gary
