MF 165 Quit Running
JohnB
01-27-2002 18:34:58
While using my disc today my MF 165 diesel quit running as if it was out of fuel. It has a full tank and was running fine before it quit. It was running for about 30 minutes before it died. I have not been able to get it started again. I'm going to replace the fuel filters, besides this does anyone have any other suggestions? For what its worth I had the fuel tank cleaned a couple of months ago (about 15 hours of use).
JohnB
02-01-2002 20:07:13
 Re: MF 165 Quit Running in reply to JohnB, 01-27-2002 18:34:58
Tractor is running! I changed the fuel filters and everything is working great. Thanks for everyone's help.
peltsi
01-31-2002 13:12:15
I changed both fuel filters on my 168, and after that on heavy load the engine died out and air had to be bleeded out before it started again. The problem was on the fuel tap, which was "jammed" on a position where is was not fully open but let some fuel though, causing lack of fuel on heavy load.
Bruce E
01-27-2002 18:45:32
JohnB, My Dad's 165 did the same thing last week.We changed the fuel filters,reprimed and she ran like a top.Also,make sure the engine shutoff is working properly. Hope this helps.Good Luck
Bruce
thebigron
01-28-2002 08:09:51
 Re: Re: MF 165 Quit Running in reply to Bruce E, 01-27-2002 18:45:32
Don't know about your 165, but my 135 has a screen "strainer" on top of the fuel cut off valve inside the tank. My tractor acted just as you describe yours doing. The strainer was cleaned and back to normal. You will be able to see with a flashlight, mirror and empty fuel tank. Can get to by removing your valve. Of course a good way to acquire new leaks if not careful. good luck
