Transmissions
mike
02-01-1999 20:11:54
massey ferguson 135 stuck in first gear?
any ideas on how to get it unstuck?
M. Smith
02-02-1999 04:13:28
 Re: transmissions in reply to mike, 02-01-1999 20:11:54
Unscrew oil filler plug beside gear shift,and with a large screwdriver or pry bar gently force the low/reverse idler backwards. It is second fork from the left side of the tractor, and if it is hung in first gear it will be the fork that is toward the front of the tractor. A slight bit of force backwards should put it in back in nuetral.
Smilin Brian
02-11-1999 11:28:00
 Re: Re: transmissions in reply to M. Smith, 02-02-1999 04:13:28
Our MH50 does that once in a blue moon. I haven't tried the oil filler bit, I unbolt the steering housing support and block it up slightly. Then I reach in with a screw driver and move the offending fork shaft into neutral.
A pain, but it works. It takes some fiddling to get the gasket back into position, and you wouldn't want to do it in a sandstorm.
