MF 130 cant find info
winston
03-11-1998 01:35:35
can anyone give me info on the above tracror i cant find it anywhere onthe net not in tractor talk not here, source for parts?
David Gates
03-29-1998 18:51:56
 Re: MF 130 cant find info in reply to winston, 03-11-1998 01:35:35
: can anyone give me info on the above tracror i cant find it anywhere onthe net not in tractor talk not here, source for parts?
The MF 130 is the same tractor as the MF 25.
They were made in Beauvias France. Manuals should
be available from your Massy Dealer. They are:
Owners Form No. 690 592 M1 and the technical manual
is 1448 569 M1. The engine is a 107 ci. continental
diesel. Engine parts can be found but other parts
are extremely difficult to get. The starter and
generator are Delco units, though and were made
by G.M. so you can get parts for them. If I figure
out how to solve more problems with these I'll let
you know as I'm going to work on my pto and hyd.
system this summer.
T'NT
03-11-1998 08:01:40
MF 130. Made 1966-1972, replacement for MF 25 made 1963-1965. Both made in France. Very similar but with sheet metal changes. 107 cu. in. Perkins diesel 27 pto hp. The number 377977 would seam to be its serial number, which would make it a 1966. 1967-1972 serial numbers started with 9A. Some parts should be available from MF dealers. If you want I can post some phone numbers of places that advertise used MF parts.
winston
03-11-1998 17:04:04
 Re: Re: MF 130 cant find info in reply to T'NT, 03-11-1998 08:01:40
: : can anyone give me info on the above tracror i cant find it anywhere onthe net not in tractor talk not here, source for parts?
: MF 130. Made 1966-1972, replacement for MF 25 made 1963-1965. Both made in France. Very similar but with sheet metal changes. 107 cu. in. Perkins diesel 27 pto hp. The number 377977 would seam to be its serial number, which would make it a 1966. 1967-1972 serial numbers started with 9A. Some parts should be available from MF dealers. If you want I can post some phone numbers of places that advertise used MF parts. tnt would you post those phone numbers for me. thanks-winston
T'NT
03-12-1998 06:37:51
 Re: Re: Re: MF 130 cant find info in reply to winston, 03-11-1998 17:04:04
1-800-662-6875 Chanute, KS. Many brands.
1-800-882-4742 Colcord, OK. Add says specializing in MF parts.
1-800-545-9967 Lawrenceburg, TN. Add only mentions MF parts.
1-800-488-3490 Brawley, CA. Many brands.
I have never had to look for any used parts yet so I have not tried any of these places.
WINSTON
03-17-1998 17:52:20
 Re: Re: Re: Re: MF 130 cant find info in reply to T'NT, 03-12-1998 06:37:51
: 1-800-662-6875 Chanute, KS. Many brands.
: 1-800-882-4742 Colcord, OK. Add says specializing in MF parts.
: 1-800-545-9967 Lawrenceburg, TN. Add only mentions MF parts.
: 1-800-488-3490 Brawley, CA. Many brands.
: I have never had to look for any used parts yet so I have not tried any of these places.
TNT,
THANKS FOR YOUR TIME AND HELP. ILL TRY THE ABOVE. ALL INDICATIONS ARE THAT THESE PARTS ARE GOING TO BE VERY DIFFICULT TO COOME BY, I PROBABLY OUGHT TO PART THIS TRACTOR OUT AND BUY ME ANOTHER.
