Massey Harris 22
cory
12-21-1999 11:35:05
How do I remove the rear hubs from the axel or are they just froze on there that bad.
Alberta Mike
12-22-1999 15:36:18
 Re: Massey Harris 22 in reply to cory , 12-21-1999 11:35:05
I'm assuming that you have a standard (non-adjustable) rear wheel on your tractor. The wheel end of the axel is tapered slightly and the big nut holds it on (although the taper really does most of the holding). The keyway of course keeps things together during rotation. You need a heavy duty wheel puller. It is anchored to the wheel either in the threaded holes in the cast iron hub or is bolted through the wheel weight holes (maybe if they're opposite each other). Either way should work. Once you tighten the inner push bolt on the puller, the wheel might come off. If not, tap the hub on the inside near the axel with a hammer. You might also apply some heat but make sure you don't ruin your axel seal, however you might be replacing it later anyways (maybe that's why you're removing the wheel, I don't know). When replacing the wheel hub, line up the keyway slots and push the hub on as far as it will go, then drive in the steel key into the slot (1/2 wheel and 1/2 axel). Drive the key in until it is flush with the outer end of the axel. Put on the bug axel nut then tighten it as far as you can preferably with a 6 point socket, then drive the hub inwards near the axel with a sledge, then tighten the axel nut again. Repeat this until the hub is secure on the axel with the last step being a tightening of the big nut. I believe there is a big washer behind the nut which should have one edge bent in over one surface of the nut to secure things but I'm not positive about this.
You could probably rent a big wheel puller from a tractor repair shop or perhaps an industrial rental company. Let us know how you make out. See ya.
