Drive train oil?????
Mr.D.
12-19-1999 19:51:45
i have a 46 massey harris pony and i was told instead of putting 90wt. gear oil in it to put automatic transmission fluid in the transmission or drive train. does anyone know anything about this? thanks.
Fred Martin
12-27-1999 18:54:00
 Re: drive train oil????? in reply to Mr.D., 12-19-1999 19:51:45
Amen Vic S
Probably even take a drink of it if running that tractor makes you constipated. Don't know about the foaming in that case though. Fred from the Mung Factory
Vic S,
12-23-1999 22:28:10
You should be using a 90w mineral gear oil. This is not 90w hypoid gear oil from an auto store. It is non foaming and is the proper oil made for Ferguson, Ford, up to around 1963 tractors. Many dealers sell 2.5 gallons for $30. I contacted an oil distribution company here in town and they had some. This guy said this is why they carry this oil. I paid $14.90 for 5 gallons. Bought two 5 gallon buckets. Penzoil also makes some but the place I talked to sells it from his 50 gallon drum. This dealer rebuilds the old MFs all the time. I have had 3 places tell me to use this and that is why I researched it. Also it is what MF recommends. Regular gear oil will foam and cause problems. Transmission fluid is not right. Hydraulic fluid is not right either in the older tractors. Call your large oil suppliers. If you live near Louisville Ky email me and Ill tell you where to get it. Vic S.
eugene maletta
07-17-2001 04:56:07
 Re: Re: drive train oil????? in reply to Vic S,, 12-23-1999 22:28:10
where can i buy hydrulic oil 9n tractor and drive train oil
i live in the rockford il or madison wi aria
thanks
Joe Ferguson
12-20-1999 03:47:23
Hi Mr D.
In my opinion automatic transmission oil is too light and contains detergent you risk deterioration and leaks in the power train.
Your pony survives 53 years with 90 oil
it may survive another 53 years.
Good luck and have fun with your little one
Joe Ferguson
