Motor exchange
john
12-17-1999 17:27:52
has anyone tried to put 9n ford engine in a to30 if so, how much trouble, thanks
B.C.
12-17-1999 18:26:52
 Re: motor exchange in reply to john, 12-17-1999 17:27:52
I never heard of it. Hot rodders claim that you can do anything mechanical if you work at it long enough, and I would bet it would seem like it in this case.
1. Engine to trans bolt pattern almost certainly different. Need some kind of adaptor plate.
2. Would need to either use the 9N front end adapted to the rest of the Massey or somehow adapt the MF front axle support, etc to the 9N block. More adaptor plates.
3. 9N clutch is single stage, most MF were double (live PTO). So somehow the MF clutch assembly would need to get married to the 9N flywheel, and trans spaced and centered properly reference crank pilot bearing, etc. See 1. above.
4. When the dust settles and the wounds are dressed, the 9N engine will be down about 10 hp from the Massey, gas or diesel.
But pessimism never got a project done, so good luck.
