WHEEL HUB REMOVAL
DRUST
12-15-1999 04:23:12
HAVE A MASSEY 22 WANTING TO REMOVE HUBS. HAVE ONE OFF BUT HAVING PROBLEMS WITH OTHER. HAVE SOAKED IT WITH PENETRATING OILS AND EVEN HAD A PULLER ON IT--1/2 " STEEL PLATE-- BUT CAN'T SEEM TO GET IT. HAVE BEAT ON IT WITH BABY SLEDGE HAMMER ETC AND NO LUCK. I HAVE EVEN DISTORTED THE STEEL PULLER PLATE. DON'T WANT TO BREAK THE HUB--SO NEED ADVICE ON WHAT TO TRY TO GET THIS HUB OFF.
cory
12-21-1999 11:41:53
 Re: WHEEL HUB REMOVAL in reply to DRUST, 12-15-1999 04:23:12
I also have a massey 22 with stuck hubs. How did you get your first one to come off? Could you tell me also where I could possibly get pwrts for mine at
thanks
ET
12-17-1999 10:09:35
I SET THE PULLER UP LIKE YOU DID BUT FOR A HAMMER YOU NEED SOMTHING WITH A LOT MORE MASS THAN JUST A SLEDGE HAMMER I USE A OLD TRACTOR AXEL THAT IS 3" IN DIAMATER AND ABOUT 40" LONG. I USE IT LIKE
A BATTERING RAM AND STRIKE THE END OF THE AXEL AND
KEEP DRAWING ON PULLER BOLTS AFTER A FEW STRIKES.
THE SHAFT IS HEAVY ENOUGH THAT YOU DON'T HAVE TO SWING IT HARD AND YOU DO LESS DAMAGE THAN WITH A HAMMER.
bbott
12-15-1999 12:07:30
I can't mentally visualize the
hub on a MF22.. but in general for
removing stuck hubs on other equipment
Very gentle heating from the outside in
has always done the trick for me.
bbott
Elmer
12-15-1999 04:34:55
Try heating the axle and then cool with water. I have parts book and operators and repair manual. Also have hydraulic equipment book for all models of that era. If you would like copies email me.
