MF35d
Steve
03-06-1998 09:06:28
Transmission keeps hanging up in one gear or another. Can diddle it with a big screwdriver but need a proper solution. Any tips on best way to start tracking this down?
Dan
03-06-1998 18:24:32
 Re: MF35d in reply to Steve, 03-06-1998 09:06:28
Shift gears slowly and move the shift lever from side to side a couple of times as you go thru neutral. Avoid any tendancy to pull up on the shifter as you're shifting. Problem is usually manageable and generally not serious. Good luck.
