Massey 135 Tach. replacement.
Tyler(WA)
12-07-1999 11:59:57
I upgraded my generator to an alternator but lost a connection point for my mechanical tachometer. Is there an electronic tach. that will fit the same hole?
Gerald J.
12-07-1999 17:45:36
 Re: Massey 135 Tach. replacement. in reply to Tyler(WA), 12-07-1999 11:59:57
The first problem is that you need one with 10 RPM increments instead of the much more common 100 RPM steps. J C Whitney used to show such, but I don't think it was as big as the original on the MF-135. You probably will have to make a shouldered washer or two (might be something in an electrical supply) to fill in the hole and to have a smaller hole for the tach. Another problem is that the ordinary automotive tach probably isn't made to be rained on.
Gerald J.
