Alberta Mike
12-07-1999 14:16:31
Re: what is it? in reply to jake, 12-06-1999 19:54:34
I have 2 of those little guys. They were made in Racine, Wisconsin from 1939 to about '46 (I think). They were the same chassis, tranny and differential as the 'Seniors', but the seniors had a 6 cylinder engine. The 101 Juniors were an 'economy' version, using a 4 cylinder, flathead Coontinental engine. They started with 124 cubic inches, then progressed to 140 and at the end of the run, I think some were 162's, although the engine block was exactly the same, only the bore being different. Most were gas and I 'think' some burned kerosene (and had rad shutters and a high heat manifold, and had a small gas tank for starting with gasoline). Many had a side pulley and a PTO at the back, but neither was 'live' so you had to have your clutch out for them to operate. The little Continentals were good engines and were still used on Lincoln welders, not too many years ago. Lots of engine 'ghosts' around on tractors and miscellaneous equipment. The 101 junior is easy to work on. I've got specs on them if you're interested. Are the side covers still on? If they are, you're a lucky man. If you got an extra set, I'd strike a deal with you. I bought one of mine as a basket case for $100 Canadian, and restored it at a total cost of about 1 grand. Tractor #2 was a running tractor with good rubber and I paid $650 but it had an aftermarket hydraulic pump, tank, and controls which I wanted for another use. I'm currently restoring that one. List a serial number and I'll let you know the 'year'. Email me at: [email protected]
