Super 90 PTO Clutch Troubles
K. Crawford
03-01-1998 20:04:39
Need information on the PTO clutch setup on a 1963 MF Super 90 Tractor. It seems to be slipping under heavy load.
Bob Due
03-03-1998 20:29:37
 Re: Super 90 PTO Clutch Troubles in reply to K. Crawford, 03-01-1998 20:04:39
: Need information on the PTO clutch setup on a 1963 MF Super 90 Tractor. It seems to be slipping under heavy load.
The pto clutch is the same as the Multipower clutch. You probably need new O-rings, clutch plates and some repairs
to the clutch housing. The housing can not be bought anymore from MF. It has some holes through it that can be
repaired by welding shut and remachining in a new location. You will have to split the tractor to get to this.
If I can be of more help please contact me at [email protected]
