Ferguson 35 hydraulics
wal armot
12-03-1999 17:45:59
I have had the tramsmission cover off to replace the gasket. The hydraulic lift now does not work. HELP
pierce fallon
12-16-1999 22:24:43
 Re: ferguson 35 hydraulics in reply to wal armot, 12-03-1999 17:45:59
make sure you reinstaled the roller otherwise it will not work and also the transfer plate must be in the proper position.I have had the same problem myself
Paul
12-03-1999 20:00:12
Wal - when you replaced the cover, did you make sure the position control levers were in front of the pump control lever? If they are behind it, you will have to remover the cover and start over. You can check by removing the right cover and putting your hand down in that area to feel if it is correctly placed.
Paul
wal arnot
01-16-2000 23:59:56
 Re: Re: ferguson 35 hydraulics in reply to Paul, 12-03-1999 20:00:12
Many thanks. Followed your advise and the old girl lifts better than ever.
