Another stupid question
Matt Marsh
12-02-1999 08:23:21
The throttle lever on my 65MF seems to be too loose, like it needs more friction to hold it in place. It won't allow the RPMs to stay up in the PTO range. There is a washer between the dash panel and the lever that is worn through. Is this the only thing that keeps tension on the throttle? Have any of you had this problem? It looks like I would have to pull the steering wheel off, and loosen a bracket on the bottom end of the throttle rod to remove the lever just to replace the washer. Are there any better solutions?
Thanks again,
Matt Marsh
Matt Marsh
12-03-1999 10:34:15
 Re: another stupid question in reply to Matt Marsh, 12-02-1999 08:23:21
I discovered the problem. The throttle lever is keyed at various points. There is a friction disk assembly under the dash panel where the keyed shaft of the throttle lever slides into. The keys on the shaft are worn off so that it can't mate with the friction disk. Looks like I'm in for some fabricating.
Matt Marsh
