Hydraulic leaks MF1130
Randy
11-28-1999 18:23:12
I have been looking to buy this 1130 turbo diesel. it runs well but leaks/shoots hydraulic fluid from around one bolt on the right rear differential housing when raising or lowering the three point. Is this an easy fix or a nightmare.
What I'm I getting myself into?
Ernie
11-29-1999 16:47:59
 Re: Hydraulic leaks MF1130 in reply to Randy, 11-28-1999 18:23:12
Does the bolt have a hole drilled in it? If so it is probably the breather and the hydraulic system is masseyively overfull. Neighbor had a 1080, 1100, and 1130. He liked the 1100 best, and it took a lotta abuse. My brother bought a 1968 1100, but it was wore out and costly to maintain, let alone improve on.
Randy
11-30-1999 14:51:13
 Re: Re: Hydraulic leaks MF1130 in reply to Ernie, 11-29-1999 16:47:59
thanks for the replay Ernie.
No the bolt does not have a hole in it. The fluid shoots from under the nut. When I had the tractor running the fluid was low enough there was no steering, but the brakes and lift seemed to operate ok.
