Ford Jubilee
Harry
12-18-1998 18:07:57
Found a nice looking, meaning new paint, Ford Jubilee on a used car/truck lot today. No one was there to talk to so I don't know what the price is. I'm going back by tomorrow or the next day or the next day to see what they want for it. Would $2000 be reasonable it it runs good?
EDDIE
11-22-1999 16:31:42
 Re: MF Hydraulics in reply to culla, 11-22-1999 04:29:46
CULLA TO REMOVE THE HYDRALIC PUMP YOU NEED TO REMOVE THE LIFT TOP , PTO SHAFT ,DRIVESHAFT COUPLER ,TWO PUMP MOUNTING PINS. PUMP WILL THEN BE ABLE TO BE REMOVED THROUGH LIFT TOP OPENING.
Moye
11-22-1999 16:43:26
 Re: MH50 stuck in reverse in reply to NormZ WI, 11-21-1999 16:04:08
The problem with the transmissions on most of these old Masseys can be handled if you shift SLOWLY!!! and DO NOT lift up on the gear leaver as you shift. Every time I get in a hurry or lift up on the gear lever, I cross gears or leave it in a gear. Maybe one day I'll learn. :) Moye
