MF Hydraulics
culla
11-22-1999 04:29:46
I am servicing an MF 35 tractor hydraulics, I cannot remove the shaft that connect power from the gear box to the wheel differential thus I am not able to take out the Hydraulic pump. This is an old tractor MF 35, using brake drum instead of the disc brake. Do I have to seperate the tractor apart to remove the shaft?
I am made to understand that to service the MF 165 with the disc bracke, you do not have to seperate the tractor.
Any advice.
EDDIE
11-22-1999 16:31:42
 Re: MF Hydraulics in reply to culla, 11-22-1999 04:29:46
CULLA TO REMOVE THE HYDRALIC PUMP YOU NEED TO REMOVE THE LIFT TOP , PTO SHAFT ,DRIVESHAFT COUPLER ,TWO PUMP MOUNTING PINS. PUMP WILL THEN BE ABLE TO BE REMOVED THROUGH LIFT TOP OPENING.
Culla
11-23-1999 05:06:10
 Re: Re: MF Hydraulics in reply to EDDIE, 11-22-1999 16:31:42
Thanks all of you, We have completed the job, thanks to your advice. Save us alot of money.
Thanks again.
Jack in NB
11-22-1999 11:28:00
Hello, culla -
Gil's comments are valid once you get the drive coupler off, but if I read you correctly you can't get down to the pump yet because of that coupler.
There's normally a cotter pin through the coupler, about the size of a 2 1/2" nail which holds it from sliding. It may have been broken off so it's not vsible, but you should be able to see the holes. If you can get a nail clear through the holes, the shaft should slide (forward, I think) to collapse so you can remove it.
Hope this helps.
Gil
11-22-1999 08:03:55
In my MF50 the PTO shaft drives the hyd pump. The shaft can be removed through the back of the tractor w/o splitting the housng. Also on either side of the housing, there is a pin held by two bolts that the pump rides on.(outside)
culla
11-22-1999 14:06:22
 Re: Re: MF Hydraulics in reply to Gil, 11-22-1999 08:03:55
Thanks,
Have a nice day.
