TO20 oil pump gear
Tom B.
11-19-1999 20:05:11
I am in he process of fixing up a TO20. I noticed the gear that turns the oil pump moves forward and back on it's shaft. Is this normal? I have the pan off so I put in new rod bearings. Before I finish the bottom end I would like to know if that gear's movement is normal. I would rather not take off the front cover. The gears teeth are not worn and seem to merge well with the gear on top of it. I put in new rings, ground the valves, & seated the head. Any info would be appreciated. thanks, tb
kurt
11-20-1999 08:24:22
 Re: TO20 oil pump gear in reply to Tom B., 11-19-1999 20:05:11
i just rebuilt my oil pump on a TO-20 and there isn't much end play. if yours is sloppy i recommend you rebuild it. the more oil pressure the better. the kit is about 50.00. you get new gears and bushings and a new spring and plunger for the relief valve. central tractor sells the kit.
B.C.
11-21-1999 11:06:19
 Re: Re: TO20 oil pump gear in reply to kurt, 11-20-1999 08:24:22
If it's like our MH50 was, the set screw that holds the driving gear to the shaft had backed out. This scored the adjacent end plate. Got it ground smooth at a machine shop. That, and the previously mentioned pump rebuild kit fixed the pump.
Shouldn't have much endplay.
