Super 101 Senior
Tim Striker
11-19-1999 14:42:02
Help. Looking for info on a tractor my father-in
Law just purchased. It is a Massey-Harris Super 101 Senior with spoke front wheels. It is model
IND, Type 5A-46. The engine in a Chrysler Ser.#
31967. What year was it made and where do we find
the ser.# for the frame? He is also looking to buy the front left (Littler) louvered door. Thanks
for any help. Tim Striker
MikeB
11-19-1999 16:38:27
 Re: Super 101 Senior in reply to Tim Striker, 11-19-1999 14:42:02
Something is a bit wrong (I think) with your information. You must have a 101 Super with a Chrysler 6 cylinder flatheat motor. According to information I have, it was a 217 cubic inch motor, model T96-T116 (whatever that means). With spoked wheels, you must have a row crop version? The Supers were all gasoline models. Now, the confusing part is the 'SENIOR' designation. To my knowledge, the Senior was another model altogether, as in 101 Sr. 102 Sr. etc. These had 6 cylinder Continental engines. They also made 4 cylinder models called 'juniors' which means nothing to you. As for the side cover (I think that's what you're looking for, or the one under the tank cover anyways), good luck. You won't find an original one that's for sure (unless you are 'super' luckey) - that's a 'pun' of course. There are guys making them, as a matter of fact I'm about to post a request for contacts on MH sidecovers so watch this forum.
Tim Striker
11-21-1999 07:51:53
 Re: Re: Super 101 Senior in reply to MikeB, 11-19-1999 16:38:27
Thanks Mike B. The tractor does say Super 101 on the side. My father-in-law called it a Senior.
My mistake. Do you know how to run the engine Ser.# to find when manufactured. Tim
MikeB
11-21-1999 17:48:24
 Re: Re: Re: Super 101 Senior in reply to Tim Striker, 11-21-1999 07:51:53
Now, that would be a a pretty tough job. I don't know if engine serial numbers were really ever used as far as 'the' tractor it was mounted into, even at the factory. I've got a little BF Avery here and I've got exactly the same problem as you do. If however it is a 101 Super, then here is where your serial number 'should ' fall.
Row Crop model - #258286 to 260717
Standard tread models - #357871 to 359424
I know all this gives you is the total production numbers, using a little subtraction about 2500 row crops and about 1650 standard tread. My 101 Juniors have an oval tin plate with the serial number on it, just on the left side on the cast iron 'tub' (which holds the motor & clutch), just ahead of the transmission casting. I think all of the MH's from this era were there. Look carefully there for a couple of very small rivets that still might be there (that held the plate on), or maybe the rivet holes, or maybe 2 sheared-off rivets (but they're very small, like maybe 1/16 inch so they're hard to find). This is probably where the plate would have been. If you find anything, then all you've got is 2 rivet holes (or rivets) and no serial plate, big deal huh?
Tim Striker
11-23-1999 12:23:46
 Re: Re: Re: Re: Super 101 Senior in reply to MikeB, 11-21-1999 17:48:24
Thanks Again Mike B... If we find it I will let you know. Tim
