MF-30E Hydro. Hyd Oil leak on engine side of flywheel.
Phillip from Pi
12-04-1998 19:42:36
I split the tractor apart and found no obvious problem with main trans seal. Has anyone seen this before?
M. Smith
12-05-1998 06:19:57
 Re: MF-30E Hydro. Hyd Oil leak on engine side of flywheel. in reply to Phillip from Pickens S.C., 12-04-1998 19:42:36
: I split the tractor apart and found no obvious problem with main trans seal. Has anyone seen this before?
Fairly common, several possibilities. I would replace the seal while there and rebush the front pump or replace the pump. Also check the converter for leaks and make sure the plate between the converter and flywheel is not cracked or loose.>>> M. Smith>> Landrum, S.C.
