TO-30 Lift Problem
David E
12-02-1998 21:52:38
Lift was working fine all day with bush-hog; however, after returning to the barn with the lift up for about 15 minutes it wouldn't go down when I lowered the control. The next day it was down, but when I engaged the PTO it raised up halfway and now the control has no effect on it at all.
Gerald
12-02-1998 21:57:37
 Re: TO-30 Lift Problem in reply to David E, 12-02-1998 21:52:38
: Lift was working fine all day with bush-hog; however, after returning to the barn with the lift up for about 15 minutes it wouldn't go down when I lowered the control. The next day it was down, but when I engaged the PTO it raised up halfway and now the control has no effect on it at all.
Did the draft control drift away from the top position?
Gerald
David E
12-04-1998 21:34:52
 Re: Re: TO-30 Lift Problem in reply to Gerald, 12-02-1998 21:57:37
: : Lift was working fine all day with bush-hog; however, after returning to the barn with the lift up for about 15 minutes it wouldn't go down when I lowered the control. The next day it was down, but when I engaged the PTO it raised up halfway and now the control has no effect on it at all.
: Did the draft control drift away from the top position?
: Gerald
The control was down about 1/4 from the top position--I didn't notice it drifting.
Alan Rogers
11-14-1999 17:12:17
 Massey Ferguson 150 electrical system in reply to Gerald, 12-02-1998 21:57:37
Tim (Utah)
11-14-1999 19:08:59
 Re: MF-35,FE-35, OR TO -35? in reply to BUC, 11-09-1999 20:04:07
I have a 1959 MF TO-35. There should be a serial number plate to the left of the steering wheel. That will give you the serial number as well as wether it's a Ferguson TO-35, MF TO-35, or a MF 35.
Tim
