Hydraulic problems with MF175
Steve
03-27-1998 16:29:51
The lift cycle is slow and jerky all the way up even when it stops at the top it still is nervous it seems to have enough power but is still shakey.loaded or not it does this.Please Help!!!
Kevin Timney
04-13-1998 00:10:19
 Re: hydraulic problems with MF175 in reply to Steve, 03-27-1998 16:29:51
: The lift cycle is slow and jerky all the way up even when it stops at the top it still is nervous it seems to have enough power but is still shakey.loaded or not it does this.Please Help!!! Steve.
I have the same problem with my MF130. Have you had any luck with a solution ?
Kevin
steve
04-17-1998 19:53:49
 Re: Re: hydraulic problems with MF175 in reply to Kevin Timney, 04-13-1998 00:10:19
: : : The lift cycle is slow and jerky all the way up even when it stops at the top it still is nervous it seems to have enough power but is still shakey.loaded or not it does this.Please Help!!!
: : Steve.
: I have the same problem with my MF130. : Have you had any luck with a solution ?
: Kevin
have not gotten any answers kevin
abdul a
04-18-1998 10:07:37
 Re: Re: Re: hydraulic problems with MF175 in reply to steve, 04-17-1998 19:53:49
: : : : : The lift cycle is slow and jerky all the way up even when it stops at the top it still is nervous it seems to have enough power but is still shakey.loaded or not it does this.Please Help!!!
: : : : Steve.
: : I have the same problem with my MF130. : : Have you had any luck with a solution ?
: : Kevin
: have not gotten any answers kevin
:how old is your tractor??
i think your hydraulic pump needs a maintinace
the hydralic system does this when the piston rings of the hyd-pump gets old.
or the levers arms and the cylinder needs just adjustment.
Gerald
04-27-1998 19:54:54
 Re: Re: Re: Re: hydraulic problems with MF175 in reply to abdul a, 04-18-1998 10:07:37
: : : : : : : : The lift cycle is slow and jerky all the way up even when it stops at the top it still is nervous it seems to have enough power but is still shakey.loaded or not it does this.Please Help!!!
: : : : : : Steve.
: : : I have the same problem with my MF130. : : : Have you had any luck with a solution ?
: : : Kevin
: : have not gotten any answers kevin
I think most likely the synchronization needs to be adjusted. There's a screw that couples the levers to the intake valve control on the pump that in my 135 vibrates to make the feed back too sensitive. This adjustment is also required when the lift cover is removed and replaced. The details are covered in the I&t manual. Essentially you lower the oil a few gallons and take off the lever and cover on the right side that sets the response speed. Then you back out the screw until it just clears the bar it touches. Its supposed to be held in place by a little bar pushing into the knurled head. That's pushed by a spring. The next time I make that adjustment, I'm going to either add a lock nut or scar the threads so it doesn't move so easily. : :how old is your tractor??
: i think your hydraulic pump needs a maintinace
: the hydralic system does this when the piston rings of the hyd-pump gets old.
: or the levers arms and the cylinder needs just adjustment.
