PTO won't engage on TO30
Mac
12-01-1998 12:40:29
I am unable to engage my PTO on my TO30. Does anyone know of any possible reasons?
Where do I start?
Thanks,
Mac
Brooksie
12-01-1998 22:02:49
 Re: PTO won't engage on TO30 in reply to Mac, 12-01-1998 12:40:29
Mac,
Are you sure the PTO shifter is getting the PTO to engage?
The PTO drives the hydraulics on the TO-30, so I would expect that the lift doesn't work as well?
Try starting it with the tranny in neutral. Then while it runs and you're off the tractor (this assumes you've got the brake pedal lock "on", or the 30 is sitting level and won't roll away (don't ask) ... anyway, once its running, hold the clutch pedal down, and try to "feel" if the PTO shifter is engaging anything ... you should feel it engage ... then let off the clutch and see if the PTO or hydraulics work. You might pull the rear axle housing inspection covers and look for something amiss there.
good luck
