MF 135 loader
Tony Revetti
11-30-1998 07:54:28
I have a 1971 MF 135 and am looking for a front loader bucket for it. Does anyone have ideas as to the proper size, and type I should be looking for? Also, I'm still trying to find an exhaust manifold for the perkins 3 cyl (gas) engine. Seems that the only ones available are for the diesels. Thanks, if you can help.
M.Smith
11-30-1998 10:17:43
 Re: MF 135 loader in reply to Tony Revetti, 11-30-1998 07:54:28
: I have a 1971 MF 135 and am looking for a front loader bucket for it. Does anyone have ideas as to the proper size, and type I should be looking for? Also, I'm still trying to find an exhaust manifold for the perkins 3 cyl (gas) engine. Seems that the only ones available are for the diesels. Thanks, if you can help.
The manifold for the diesel will fit the 3 cyl. gas tractor also. The original manifold on some of the 3 cyl. gas tractors was made up a little heavier than the diesel manifold,and the rest had the same manifold as the diesel.
Gerald
11-30-1998 08:32:09
I had a MF-236 loader on my MF-135. It was a little heavy for the tractor and is a good match for the JD-4020 that I've moved it to. I put 11L-16 front tires on the 135 on 8" wide rims so they didn't sink into the dirt.
Gerald
