What is it? MH PGA9015A
James
11-29-1998 23:06:14
This past weekend I found and old tractor in the woods in AR. It is a Massey Harris, the serial # read PGA9015A.
The tractor is about the size of a farmall cub. It has 24" rear rims. The starter and distributor cap are missing as are the fuel and radiator caps. It appears to be complete otherwise. It has a belly mower attached to the cultivator arms which are hydraulicly controled.
This tractor has probably been setting for over 10 years.
Thanks
Tom from Ontario
12-03-1998 17:57:55
 Re: What is it? MH PGA9015A in reply to James, 11-29-1998 23:06:14
: : This past weekend I found and old tractor in the woods in AR. It is a Massey Harris, the serial # read PGA9015A.
: The tractor is about the size of a farmall cub. It has 24" rear rims. The starter and distributor cap are missing as are the fuel and radiator caps. It appears to be complete otherwise. It has a belly mower attached to the cultivator arms which are hydraulicly controled.
: This tractor has probably been setting for over 10 years.
: Thanks
James: That number indicates a 1949 Pony with adjustable axle. Yes, they were built to go against tractors like a Cub or a JD LA. Apparently their electrical systems were all Auto-Lite. Pour the Rust Blaster to it and Good Luck. Tom
