MF35 NOT STARTING
Raymond Farrell
11-29-1998 05:35:44
I AM ABOUT TO PURCHASE A MF35 DIESEL 4 CYLINDER,I LIVE IN N.IRELAND AND THEY HAVE A TERRIBLE REPUTATION FOR NOT STARTING FROM COLD, I AM WONDERING IF ANYONE HAS A SOLUTION TO THIS PROBLEM,PLEASE.....
GREG BAHR
12-11-1999 17:32:21
 VALUE OF M-F 204???? in reply to
Jack in NB
11-29-1998 13:32:11
 Re: MF35 NOT STARTING in reply to Raymond Farrelly, 11-29-1998 05:35:44
Hi Raymond -
If the engine compression is up (engine in good shape and not burning oil or having a lot of blowby out the crankcase vent when hot), glow plugs or thermostart working, and a good battery, ours starts to about 40 deg F. Below that, a block heater is useful, or a sniff of ether. There is a block heater here (110 v, 500 watt) which splices into the lower rad hose. You should be able to access a 220 v one in your area, if not already fitted. The heater helps even at 50 deg!
They're a great tractor when all systems work! and you have economical parts sources there - we use your Vapormatic products.
Good luck, and don't pay too much for it. $2500 Cdn is average around here.
Drop me a note if you have other questions.
Jack Wetmore in NB Canada.
