MF50 Governor.......Help!
Levi
11-27-1998 05:02:35
I have a MF50 that I have restored and it is cherry, but the governor will not work properly. The arm out of the timing cover is operating but it seems to have little effect on the throttle. I also have a 35 that works perfectly and I have tried to adjust the 50 to work like the 35 witout any luck. They both have Zenith carbs and except for this problem they are a delight to use and operate. Does anybody have any ideas what I am overlooking?
WILL
12-06-1998 17:33:52
 Re: MF50 Governor.......Help! in reply to Levi, 11-27-1998 05:02:35
: I have a MF50 that I have restored and it is cherry, but the governor will not work properly. The arm out of the timing cover is operating but it seems to have little effect on the throttle. I also have a 35 that works perfectly and I have tried to adjust the 50 to work like the 35 witout any luck. They both have Zenith carbs and except for this problem they are a delight to use and operate. Does anybody have any ideas what I am overlooking?
Levi
Sounds like there is a malfunction in the gov. Most likely a spring or bearing. You need to take it apart and look inside.
