Hydrolic Systems for MF135
Ron Stamper
11-26-1998 15:02:37
I am looking for information--perferably online--about repairing the hydrolic system on a MF 135. My problem is the hydrolics work at high RPM, but when the tractor idles down, they won't hold, lowering the three point hitch to the ground. Also, what parts could be causing this problem--the seals, the valves, or what?????
Gerald
11-26-1998 16:13:30
 Re: Hydrolic Systems for MF135 in reply to Ron Stamper, 11-26-1998 15:02:37
: I am looking for information--perferably online--about repairing the hydrolic system on a MF 135. My problem is the hydrolics work at high RPM, but when the tractor idles down, they won't hold, lowering the three point hitch to the ground. Also, what parts could be causing this problem--the seals, the valves, or what?????
The I&T manual covers it fairly completely. Probably you need a pump or pump rebuild kit. Check CT 888-8ct-farm for parts. You have to identify the pump before you order the rebuild kit.
Could be a leak somewhere too or the lift cylinder seals. CT has those too.
Gerald
