Help identify model
Matt
11-20-1998 08:56:33
Just bought at a county auction a 1962 MF tractor.
I'm not sure what model it is, and it doesn't look
like any of the photos I've found on the web.
The county painted the tractor bright yellow, so
paint can't help. It has an enclosed cab.
It has both a throttle control and an accelerator on
pedal on the floor. The engine tag has paint all
over it but it does say "Continental". It is a
gas engine, not diesel. The tag also says something
like "US Department of ARMY", so this tractor was
some kind of a military model.
I would like to find a good picture of this tractor,
to see what the paint is supposed to look like.
Does anyone know what model this tractor is? Thanks.
Gerald
11-20-1998 11:08:48
 Re: Help identify model in reply to Matt, 11-20-1998 08:56:33
: Just bought at a county auction a 1962 MF tractor.
: I'm not sure what model it is, and it doesn't look
: like any of the photos I've found on the web.
: The county painted the tractor bright yellow, so
: paint can't help. It has an enclosed cab.
: It has both a throttle control and an accelerator on
: pedal on the floor. The engine tag has paint all
: over it but it does say "Continental". It is a
: gas engine, not diesel. The tag also says something
: like "US Department of ARMY", so this tractor was
: some kind of a military model.
: I would like to find a good picture of this tractor,
: to see what the paint is supposed to look like.
: Does anyone know what model this tractor is? Thanks.
It may truly be a military design. But various models of MF tractors used different sizes of Continental engines. Look for Z 120 through Z-145 on that engine tag. That will give a hint.
Is the front of the hood/grill rounded or squarish?
Gerald
matt
11-20-1998 15:40:54
 Re: Re: Help identify model in reply to Gerald, 11-20-1998 11:08:48
: It may truly be a military design. But various models of MF tractors used different sizes of Continental engines. Look for Z 120 through Z-145 on that engine tag. That will give a hint.
: Is the front of the hood/grill rounded or squarish?
: Gerald
I would say that it is "Sqauarish". Is the enclosed cab
a common feature or is that unusual for 1962 MF models.
I'm wondering if the cab is something that may give
a clue as to the model of this tractor.
Thanks, Matt Walli - Powers, MI
Gerald
11-20-1998 17:20:04
 Re: Re: Re: Help identify model in reply to matt, 11-20-1998 15:40:54
: : : It may truly be a military design. But various models of MF tractors used different sizes of Continental engines. Look for Z 120 through Z-145 on that engine tag. That will give a hint.
: : Is the front of the hood/grill rounded or squarish?
: : Gerald
: I would say that it is "Sqauarish". Is the enclosed cab
: a common feature or is that unusual for 1962 MF models.
: I'm wondering if the cab is something that may give
: a clue as to the model of this tractor.
: Thanks, Matt Walli - Powers, MI
A cab is relatively unusual in a tractor of that size, more unusual for that vintage. Cabs of that era tended to just be rain covers, weren't dust tight, not well ventilated and were not strong enough to stand a roll over. They were most often supplied by makers other than the tractor maker, such as Hiniker and Excel. And tended to be very square.
The MF-135 hood is kind of squarish, more than round up front. Has an automotive type hood that opens from the side to get to the gas tank.
The serial number and engine model should be on that Continental tag. Attack it with paint stripper, not sand blasting. The numbers should have been stamped, while the model number may be part of the engraved like the Continental name. Presuming the engine hasn't been replaced that still could be the best hint of origin. The serial number tag for a MF-135 is located on the cowling below the instruments to the left of center about knee high.
Gerald
