: : : I am looking at MF 135's and I can't seem to find any info on them in the web pages I can find. It seems they all deal with pre 1965 tractors (usually MH). Does anyone know of where a good web site is. : : : OBTW, I have a chance to buy a 135 SN 27xxx, with a parsons front end loader. The tractor has a 4 cyl gas motor. One concern I have though, it seems the bracket/yoke the front shaft that would go through to a pump is shattered on top, hence they have put a rear pump on. Is this fixable? Asking price is $4500.: : That yoke the front shaft would go through is the front axle pivot pin mounting. Kind of important for holding up the front of the tractor. MF-135 with loaders can break the front axle. Mine has been welded. It's had a MF-236 loader for a long time which is big for the MF-135. That loader came to me with a rear pump, but after that was stolen one foggy day, I installed my own front pump. : : $4500 is probably reasonable with loader, but fixing that front axle support may be a real pain. I hope to get more for mine soon as I finish fixing a few things and that's without the loader which I've mounted on my JD 4020. : : Check the salvage yards for that front yoke and help for swapping it out before you settle on a price. : : Gerald : : Thanks for the help. I certainly appreciate it. Do you know approx the horse power of the 4 cyl gas engine? Depends on whether its a deluxe or special model. The Deluxe is a Z-145 Continental engine rated at 35.4 in my manual. The Special (fewer gauges and less fancy seat) is Z-134 rated at 34.6 hp. Gerald
