French mf25 ?
phillip yancey
11-14-1998 07:47:32
I have a french built MF25 model 25 SNMY sn. 1106026 with a Perkins A4.107 diesel engine (28 hp or so) .
The MF20-25, MF25, MF30,(MF130) are supposedly similar french tractors, and everyone excludes them from being referenced.
The manuals I have are owners(operator), maintenance, parts(fr./eng.). Jensles.com has copys of the original manuals and have no new information.
My problem is the hydraulic/oil pump under the transmission case is missing it's gear! the previous owner threw it away rather than repairing the pump and valve body of the 3 pt hitch . The parts books only refers to it as a oil pump with gear assembly , no description of how many teeth the gear has. I know that the gears are 8dp 14 1/2 degree pressure angle. I could make a new gear if I knew how many teeth it has ? A brief sketch of the gear hub length dia etc would help.
parts book ; gear 967 075 M1, pump 967 726 M1 or pump 968 655 M1. Do you have any infomation or references to the MF20-25, MF25, MF30, MF130 ?
Diamond Farm Book Publishers cary several books and videos (which I have not seen); Massey Tractors C.H. Wendel & Andrew Morland ISBN# 0-87938-618-5 $19.95 Massey-Ferguson Tractors Michael Williams 0-85236-203-x $29.95 The Massey Legacy volume 1 (of 2) Jhon Farnsworth 0-85236-403-2 $39.95 Massey On Parade video Farming Press Productions 0-85236-410-5 $39.45 The Massey=ferguson Tractor Story video Michale Willams 0-85236-248-x $34.95
do they give the history of the french tractors ?
Thank You Phillip Yancey work 503-228-7259 cell 503-329-5734 fax 503-228-8180 home 360-834-2787
My new email address is [email protected] , please use this new one.
