Identifying ferguson tractor
mike bennison
11-10-1998 19:45:51
I have just picked up an old ferguson tractor.
On the hood all it says is ferguson.
It is a four cylinder engine.
I would like to know how to correctly identify
the model and year of manufacture
mike
RW
11-10-1998 19:59:20
 Re: identifying ferguson tractor in reply to mike bennison, 11-10-1998 19:45:51
: I have just picked up an old ferguson tractor.
: On the hood all it says is ferguson.
: It is a four cylinder engine.
: I would like to know how to correctly identify
: the model and year of manufacture
: mike
You need to look above the steering wheel in the center of the dash. There should be a serial #. Once you have it you can use it to tell what year and model it is. You can do it from here at Yesterday's Tractors by using their info. It's on the home page but I forget exactly what the Icon says. You may also want to visit the Unofficial Ferguson Web Page. This is a interesting place to find out a little about which tractor you have. It's probably a TO-20 or TO-30. On the side of the block the motor will say it's a Z-120 indicating a TO-20 or a Z-129 indicating a TO-30. If there is an oil filter on the side of the motor then it's probably a TO-30. If not and there is a plate under the tractor (oil pan) then it's probably a TO-20. If there is a hole in the dash for air then its probably a TO-30. Hope this helps. RW
