Massey fergusson 88 "runs lousy" lots of black smoke
Pat Griffin
11-10-1998 16:31:11
distributor popped out,i replaced at TDC on#1 and it hasn't run the same since. i have installed new plugs,wires,cap,rotor,condensor.adjuusted valves &timing.it still doesn't run any better.when i pull a plug wire from the cap it appears to run better with the spark jumping into the cap.iam extremely puzzled can someone please offer some suggestions.thankyou
Bob
11-10-1998 16:56:32
 Re: massey fergusson 88 "runs lousy" lots of black smoke in reply to Pat Griffin, 11-10-1998 16:31:11
: distributor popped out,i replaced at TDC on#1 and it hasn't run the same since. i have installed new plugs,wires,cap,rotor,condensor.adjuusted valves &timing.it still doesn't run any better.when i pull a plug wire from the cap it appears to run better with the spark jumping into the cap.iam extremely puzzled can someone please offer some suggestions.thankyou
If it runs better with the spark jumping the gap, it sounds like too much fuel. The extra gap allows the voltage to build up to a higher value before the plug fires. Are you really sure its timed right?
Though the black smoke is definitly too much fuel. Check the float.
Good luck!
Tom from Ontario
11-10-1998 17:20:00
 Re: Re: massey fergusson 88 "runs lousy" lots of black smoke in reply to Bob, 11-10-1998 16:56:32
: : distributor popped out,i replaced at TDC on#1 and it hasn't run the same since. i have installed new plugs,wires,cap,rotor,condensor.adjuusted valves &timing.it still doesn't run any better.when i pull a plug wire from the cap it appears to run better with the spark jumping into the cap.iam extremely puzzled can someone please offer some suggestions.thankyou
: If it runs better with the spark jumping the gap, it sounds like too much fuel. The extra gap allows the voltage to build up to a higher value before the plug fires. Are you really sure its timed right?
: Though the black smoke is definitly too much fuel. Check the float.
: Good luck!
Pat: 88 manual says timing is 5 degrees before TDC. Try it. May help. Tom.
Gerald
11-10-1998 19:27:52
 Re: Re: Re: massey fergusson 88 "runs lousy" lots of black smoke in reply to Tom from Ontario, 11-10-1998 17:20:00
: : : : distributor popped out,i replaced at TDC on#1 and it hasn't run the same since. i have installed new plugs,wires,cap,rotor,condensor.adjuusted valves &timing.it still doesn't run any better.when i pull a plug wire from the cap it appears to run better with the spark jumping into the cap.iam extremely puzzled can someone please offer some suggestions.thankyou
: : If it runs better with the spark jumping the gap, it sounds like too much fuel. The extra gap allows the voltage to build up to a higher value before the plug fires. Are you really sure its timed right?
: : Though the black smoke is definitly too much fuel. Check the float.
: : Good luck!
: Pat: 88 manual says timing is 5 degrees before TDC. Try it. May help. Tom.
Check the needle and seat. Replace them. Check the float for actually floating. Check the float level. Check that the choke cable actually opens the choke. Check that the air filter is clean and then remove the bird's nest from the intake stack. Set the timing with a timing light.
Gerald
