Battery cover
wayne
01-23-2002 16:50:35
does anyone know if someone is makeing reproduction battery covers for the colt or mustang tractor. thanks wayne
jim
01-24-2002 16:44:21
 Re: battery cover in reply to wayne, 01-23-2002 16:50:35
Wayne - I'm restoring a 1953 Mustang and am going to use the battery cover that was used on the original 6 volt , exterior battery of my 1963 Super Dexta Ford. This is a long answer but, from the Mustang parts book, this cover appears to be very close to the original. However , these covers will probably be as scarce as hens teeth also. Hope this helps.
Mike U.
01-25-2002 08:43:26
 Re: Re: battery cover in reply to jim, 01-24-2002 16:44:21
I'll have to likely make one up myself. I too am working on a 53 Mustang. Have the gas tank off, and coated both outside and in - should last forever now. Now in the process of checking hydraulics, and painting bits and pieces. Certainly nice to work on something that was built in a sensible fashion, can be reached without crawling underneath a lot.
Could we see a picture of the cover?
Thanks.
jim
01-25-2002 17:21:54
 Re: Re: Re: battery cover in reply to Mike U., 01-25-2002 08:43:26
Mike -I'm afraid I don't have the ability to produce a picture of the Dexta battery cover. However, it is made of a heavy hard rubber composition and black in colour with openings in each end for the cables. I hope this helps. The only other Massey battery cover reproductions I've seen are for the 20 and 22's.
jim
01-25-2002 17:21:28
