Massey fersuson 165
warren
01-23-2002 12:51:31
i purchased a massey 165 out of africa and need some help in figuring out the hydrolic system. what i need to know is how i can use the threepoint hitch and the hydrolic system system with a sprayer that is hooked up to the pto and also the hydrolic system. i need to be able to raise the sprayer about 18 inches off the ground and be able to move the spray arm from right to left with the external hydrolic controls. what i have found is that the three point hitch has to be raised all the way up before the hydrolic lines will become activated and can be used. the question is, is there a way i can use the hydrolic system without raising the three point hitch all the way up. i would appreciate any help anyone can give. thanks warren
Gordon Lueder
11-28-2002 07:41:11
 Re: massey fersuson 165 in reply to warren, 01-23-2002 12:51:31
There is a stand pipe in front of seat and to the right.The cover is about 3x4 with 2 hold down bolts. Massey made a spool valve to go on top so you can run indpendt hyd.Part no. is 677 421 this a dual spool single spool part no. is677464. If you do not want to buy a valve tie the hitch down. I might have a valve.
