MF 70 industrial tractor/ backhoe value?
McIrish
01-22-2002 17:09:16
I have a chance to purchase a 1976 MF70 industrial tractor loader/ backhoe. The machine is in fair shape, it runs well, has hydrostatic trans, pins and bushings in the hoe are good and it doesn't seem to have any welds anywhere but the bucket. problem, the machine has no brakes, what kind of job am I looking at? The problem with the brakes is the brake bands, I have changed the steering brakes on a JD450 is the same kind of deal? The machine is powered by a 3 cyl perkins diesel and has a full heated cab, they want $7,500.00 for the machine, would this be a good buy? Thanks for the help McI
Brian
04-12-2002 19:20:09
 Re: MF 70 industrial tractor/ backhoe value? in reply to McIrish, 01-22-2002 17:09:16
I bought my MF 70 2 years ago with 100 hours on a rebuilt 4-138 engine and a new hydraulic pump for the loader/backhoe controls. Everything else worked just fine. It cost me $8000. so I don't know if it was a good deal or not but I haven't had any troubles except hoses breaking. I hope this helps for a comparison.
Dave
03-17-2002 21:45:09
Bought one last year. Blown motor, needed some lines replaced, and new glass in cab. Paided $2900.
After repairs it should end up around $5k-$6k.
Still happy but you'll find parts are hard to find. Mine was built in 1978.
marlowe
01-24-2002 16:30:00
the 70 hase a A4-318 4 cyl. 84 hp. perkins not a 3 cyl
michelle
11-01-2004 06:33:13
 Re: Re: MF 70 industrial tractor/ backhoe value? in reply to marlowe, 01-24-2002 16:30:00
that's the engin mine has. My husband passed away and I have an offer for 5,000. Should I take it and go or hold up for more money. Mine also has no brakes otherwise runs and works great. I can't seem to find any information on it on the web. Any help would be appreciated. Thank's.
Tim
01-22-2002 18:33:26
I have an MF 40 Ind. and it is a very good unit, I also had no brakes and had them done for about 900.00 its not the parts but it is very labor intense. PS make sure you have the actuators checked, my mechanic didnt and had to redo the job which meant lots more down time. Good Luck.
