CAV pump volume adj.
Mike
01-21-2002 19:43:25
Does anybody know how to turn up the fuel volume on a 3 cylinder CAV pump for a perkins A3-152? What pressure do I set the injectors to start spraying at? If I lower the pressure a couple hundred PSI, will the volume go up? THANK YOU; MIKE
Daryl, RSA
02-17-2002 12:03:12
 Re: CAV pump volume adj. in reply to Mike, 01-21-2002 19:43:25
Do you still require this info. I can get back to you with Perkins specs. if you want
