Continental engine
Keith Munday
01-21-2002 05:46:44
Where can I find a rebuilt or new four cylinder gas engine? Continental Z134 for a 202 Massey?
Rental Service Corp
12-10-2002 06:15:42
 Re: Continental engine in reply to Keith Munday, 01-21-2002 05:46:44
I a looking for a fuel soleniod for a continental engine. I have a part number of A75-16A, the engine number is TM27-4761-97030278. If you can help please call or email me. 706-596-5138 x216 Thanks, Tonya
Tony
01-21-2002 11:18:35
Keith,
I have a massey 202 workbull and have used it for several years with a loader. I am unfamiliar with the 290 6cyl. My tractor has a continental z134 gas engine (4 cyl). The parts are easy to get for this engine, but sometimes more difficult for the rest of the tractor because it is an industrial that alot of people are unfamiliar with. By the way this has been a great little tractor for me.
Ron
01-21-2002 10:09:32
The Z-134 was also used in the F-40 Fergusons and the TO35 masseys.It is a great strong engine that is worthy of a rebuild.Parts are readily available and this engine is quite easy to overhaul.I would rebuild the one you have as long as the block is not cracked or unsevicable.New cylinder sleeves and pistons,rings,gaskets,bearings etc. are available.It is also quite easy to do a little basic high performance work to the head to make this little giant perform even better.I have an F-40 Ferguson with a Z134 and love it!
Ken
01-12-2004 15:40:19
 Re: Re: Continental engine in reply to Ron, 01-21-2002 10:09:32
I'm just browsing z134 and MF 35 posts and ran across yours. I am about to reassemble my Z134 and I'd like to try the "little basic high performance work to the head" you suggested. Can you be more specific about the performance work you did?
Dave_Id
01-21-2002 08:23:33
The 202 came with a 290 cu.in. 6 cyl. Continental. Why are you looking for the Z134?
brmax60
01-22-2002 19:23:18
 Re: Re: Continental engine in reply to Dave_Id, 01-21-2002 08:23:33
Dave This has my interest tell me more Id been tinkerin with the idea of a replacement
i have one in the shop, sorry for me the typical gonna do somthing someday. the blocks cracked Z134
Keith L. Munday
01-21-2002 08:25:42
That's what I just pulled out of my tractor.
Ray
01-21-2002 07:31:55
I think that Massey used that engine in the MF 34 and 44 swather up until the late 60`s. We probably have some in the back yard from salvaged swathers. I think that it was also used in the MF 35 combines (not sure but I can check if it helps you out.
Ray
Keith L. Munday
01-21-2002 08:23:27
 Re: Re: Continental engine in reply to Ray, 01-21-2002 07:31:55
Thanks for the info. Any help will be appreciated.
Previous owner ran the engine with no oil.
Dave_Id
01-21-2002 08:38:24
 Re: Re: Re: Continental engine in reply to Keith L. Munday, 01-21-2002 08:23:27
I'd place a wanted ad in the YT classified, and see what comes up for a 290. According to the Massey Data Book, only 223 were made. It would be great to restore this one with a 290 since it's so rare. Perhaps you can get a motor out of a MH 55. Don't know if it would drop right in, but it would make one heckuva puller
ALAN
01-21-2002 16:47:22
 Re: Re: Re: Re: Continental engine in reply to Dave_Id, 01-21-2002 08:38:24
I think I know where the confusion is coming from. The Massey Harris Co. actually made 2 different 202 models. The 1st was made in the early 40's and was a very heavy and very rare tractor. As stated above - it used the 290 cu in engine. The other 202 was a Work Bull. It was esentially the same as the Ferguson 35 or Massey Harris 50 and was made in the mid to late 50's. It was an industrial of the same family as the 303 work bull (based on the 333) and the 404 (based on the 444). The "202" was to show it in the same family except the only thing they had in common was gasoline and 4 tires. Two completely different designs. Hope this helps - ALAN
