Sticking differential lock
Rick (ont)
01-20-2002 10:13:15
We have a 165 that lately has been hard to get the pedal to go down for the diff. lock. When it finally does go down and lock up the rear wheels it will not release.Is the problem just where the pivot point on the actual pedal or is the problem usually more in the rear end.
Fieldman12
01-20-2002 21:03:58
 Re: Sticking differential lock in reply to Rick (ont), 01-20-2002 10:13:15
I bet all that you need to do is just oil the linkage down real good with some penetrating oil. I have had a 165 and 255 that both had the problem you described. The best way to do it is jack up the right rear wheel and spray everything down real good. Make sure the tractor is in neutral and rotate the tire by hand and lock and unlock the differential until it begins to work like new.
