MF 85 Riding Lawn & Garden Tractor
John Strunck
11-04-1998 17:06:31
Hello All,
Where can I get a service manual for my MF 85 Riding Lawn & Garden Tractor? Also looking for parts source and date of manufacture.
Thank You,
John Strunck III
Phil in MS
12-02-1999 07:16:58
 Re: Re: Re: stabilizer bars? in reply to Matt M, 12-01-1999 20:28:52
Matt, I only use one bar on my MF 255d which is about the same horsepower as your 65! I found that using two was just too much trouble if you were changing implements often! The chains should keep the implement from swinging too far from side to side! One bar will control your implement enough to cultivate or do other detail work!
I purchased my tractor in 1976 and I probably stopped using two bars in the first two years! Its never seemed to be a problem! One advantage that I can think that two bars have is if you are bush hogging heavy material and lose a hitch pin the unit will remain on the tractor because of the bar!
